Hi, I installed your Nadia demo and a production site to which I installed the Nadia template I just bought. I've been trying for 2 hours to replicate your Example Style 1 but I can't get the header background image to work. The Header Image(s) option in the Styling tab of the template isn't working. It'll let you choose an image but it won't keep your selection. In your example style, you don't seem to have done it that way either.
Could you please give me some step by step instructions how to achieve the header image with the superimposed text.
Thanks,
Lio
Update: While waiting for your reply I finally figured out that the header background image in the template settings only works if you have a published module in the showcase position. I hope this helps other users with the same issue.
L
