1. cuervo
  3. Wednesday, 01 February 2017
Hi, I installed your Nadia demo and a production site to which I installed the Nadia template I just bought. I've been trying for 2 hours to replicate your Example Style 1 but I can't get the header background image to work. The Header Image(s) option in the Styling tab of the template isn't working. It'll let you choose an image but it won't keep your selection. In your example style, you don't seem to have done it that way either.
Could you please give me some step by step instructions how to achieve the header image with the superimposed text.
Thanks,
Lio
Update: While waiting for your reply I finally figured out that the header background image in the template settings only works if you have a published module in the showcase position. I hope this helps other users with the same issue.
L
Done thank you!
Hi Lio
Thank you for bringing this issue to our attention.
We have just updated our Nadia template which will resolve any issues with the selected images not been saved and also an issue on adding multiple images in one session. For details on updating your template may I suggest the following article.. http://joomla51.com/tutorials/item/updating-your-template
Hello, since updating to Joomla, the template headers for Nadia are not showing the images for our site. They are still in Styles, but simply not showing on the site. I have redownloaded the latest template from your site to no avail.
You appear to be loading two version of jQuery which is causing some conflict issues. Firstly may I suggest disabling any plugin you are not using as you have quite a few installed (Extensions -> Plugins).
May I also suggest installing jQuery Easy which ensures only one copy of jQuery loads... https://www.joomla51.com/tutorials/item/resolving-javasript-errors-in-joomla-using-jquery-easy
Hello we have disabled, but this has not fixed the problem. Can you advise of the next step?
May I suggest sending temporary administration access to your Joomla installation to [email protected] and we will jQuery Easy for you. For our reference please paste a link to this post in your email.
Done thank you
You still appear to have a large number of plugins installed. If you allow us access to disable your plugin we will see can we find the offending plugin.
OK Please go ahead thank you
We still do not have the access rights to disable your plugins.
Please go ahead now :)
Issue has been resolved.
Hello, I have just emailed you as issue has recurred - can you advise which plugin caused the previous issue?
Checking your site on both Firefox and Chrome, your header image appears to be displaying without issue.
I have noticed this image is very large in filesize (8,250.58 KB) which is causing it to be quite slow to appear.
