1. mediafrog
  4. Sunday, 26 February 2017
hi ciaran,
please have a look here:
http://ufs-marcom.ch/j3/index.php/de-de/
on the menu item "unser Angebot" is a menu called webdesign with two submenus. this submenus are difficult to click. how can I make it better?
thank you again for your assistance.
regards
grit
hi ciaran,
strange: now it works fine.
If the issue arises again try adding the following to the Custom CSS field of your templates parameters...
#container_hornav .hornav li:hover > ul {
top: 62px;
Hi ciaran,
unfortunately it doesn't work with this code.
regards
grit
Hi ciaran,
I got no answer till now. The submenu doesn't work very well.
regards grit
another question: how can I see my topics in the forum without click in the email?
Hi Grit
Could you ensure that you have the latest download of your template installed (http://joomla51.com/tutorials/item/updating-your-template).
To access your posts you can click the cog icon at the top right of this page.
hi ciaran,
ok, I will download the latest version.
Do I lost my own settings after updating the template?
No template settings would be lost by updating.
hi ciaran,
now I updated the template, but the submenu (starting on the main page) is not good. When I open a menu and go than to "Unser Angebot/Webdesign" the submenu is fine.
hope there is a solution.
regards
grit
