1. crimle
  4. Tuesday, 01 February 2022
I bought the brand new Version of J51_Skylar_J4 today. Unfortunately I am not able to install it or to be more precise: make it work.
Installation was successful. But when I open System > Site Template Stiles > J51_Skylar - Default there seems to be an incomplete template:
The «General» tab is completely empty
Also the «Module Widths» tab is empty as well
The Front-End displays an error message «500 behavior::caption not found.»
I tried to delete the previous folder templates/j51_skylar (containing the Joomla-3-version) and reinstalled J51_Skylar_J4 with the same result. I am pretty sure that the installation process did only half of the job it should have done.
Thank you and kind regards
Chris
We have just updated the Skylar template. Updating your template to this latest download should resolve these issues for you. For details on updating your template may I suggest the following article.. https://joomla51.com/tutorials/joomla-basics/updating-your-joomla-template
If the issues persist after updating, may I suggest sending temporary administration access to your Joomla installation to [email protected] and we will examine this issue further. For our reference please paste a link to this post in your email.
Skylar works now.
I got the solution now :-) The PHP settings for «max_input_vars» were too low. After increasing the value significantly the template settings mentionned above could be saved. Everything is ok now.
Thank you so much!
Kind regards
Chris
I have the same problem. After installation i have the same message
I used the Coupon you gave to Rolf Dautrich. Is this Coupon for everybody to Update Skylarto Joomla 4?
Does the following resolve the issue for you?...
1. Delete override folder from your template (../templates/j51_skylar/htm/l
2. Upload the template again via your Exstension Manager
No it does not. The «General» tab and the «Module Widths» tab are as empty as a white sheet of paper. Right now I had the idea to try installing J51_Emani_J4 which I bought a couple of days ago. With J51_Emani_J4 everything works fine. Also the Front-End is doing well, no error message «500 behavior::caption not found.» any longer.
So there must be something wrong with J51_Skylar_J4.
Kind regards
Chris
we have the same problem with skylar. the installation went without any problems but if we set skylar as the main template the frontend shows "500 behavior::caption not found". we also installed nina and set it as the main template - it works without any problems. but if we switch back to skylar it shows the same problem like before. it seems something must be wrong with skylar :( any ideas?
I have new findings to report:
«1. Delete folder ../templates/j51_skylar/html»
Now the Front-End is doing well, no error message «500 behavior::caption not found.» any longer.
«2. Upload the template again via your Exstension Manager»
The folder ../templates/j51_skylar/html is recreated and the error message «500 behavior::caption not found.» is back.
The reason for the error message must be somewhere in this «html» folder. I guess I can not go on without this folder, since essential features of the template might be affected. Right?
By the way:
The tabs «General» and «Module Widths» are no longer empty, after repeatedly installing the template.
Chris
  1. https://tierschutz-steckborn.ch/j4/
Hi Chris
Thank you for the update.
General and Module WIdths tab will populate once you click any of the sidebar items within those tabs.
On which menu item type is the 500 error occurring? Eg. What is your homepage menu item type?
But there were no sidebar items within those tabs! I am very familiar with your templates and I am using a number of them. I swear: those tabs were completely empty. Anyway, they are visible now for heavens' sake.
Menu type is «Featured Articles».
Chris
Hi Chris
For now, you can just delete the /html/com_content/featured folder as that is the item with the issue. We are currently working on an update to resolve this issue.
Deleting the folder /html/com_content/featured does not only apply to the home page. There seems to be a side effect to some menu items of the type «category blog» as well. Astonishingly enough not all category blog menu items are affected.
These pages are a complete mess and there is an error message «2 arguments are required, 1 given»
Über uns > Statistik
Mitmachen
Melden > Aufgefundene Tiere
Melden > Vermisste Tiere
Melden > Tiere suchen ein zuhause
Beitragsarchiv
These menu items are also category blogs but they are all right. I do not understand why.
Über uns > Verein
Über uns > Vorstand
Über uns > Einsatzgebiet
Über uns > Statuten
Über uns > Jahreshefte
Unterstützen
Kontakt
Links
Kind regards
Chris
With the new version of J51_Skylar the error message
«500 behavior::caption not found»
is gone. But instead we have a new error message
and the layout is a complete mess. See here: https://tierschutz-steckborn.ch/j4/
I just sent temporary administration access to my Joomla installation to [email protected]
Chris
on my site "guenther-test.de" SKYLAR works.
This site is just to test Joomla 4 with some extensions like SKYLAR Template Extensions, Phoca Gallery, SIGPLUS, Allvideos etc.
Ok. Do you use menu-item-type «category blog» or «featured articles»? Or is it «Single Article»?
Hi Chris
I have updated your template to the latest download and your site appears to be now loading without issue.
thank you so much. The site seems to be working all right now. But I have to report another issue with this template.
- Open «J51_Skylar» template stile
- go to «Modules Style Overrides» tab
- click the [+] button in order to add a new override
- select position «Base-2B» oder «Base-2C»
- add some parameters (or leave them blank, it does not matter)
- click the [Save] Button
Result:
- The settings are NOT saved
- The template will close immediately although we click [Save] (not [Save & Close])
By the way:
- position «Base-2A» is ok
Chris
Is this question for me? If yes, the articles are 3 simple single articles
Hi Chris
This issue should be now resolved. It appears there was an issue with the `Base-2A` entry of your overrides where the saved data for the background image was pointing to an image that did not exist. Removing this entry and we can now add new entries without issue.
This UI element is a Joomla core element that appears to have an issue gracefully handling certain data errors. We will create a ticket on the Joomla repo.
  • 2
