Joomla51 templates include an array styling options allowing you to customize the look and feel of the template design. To demonstrate the potential of these features we have included a number of styling alternatives on each template demo under the ‘Example Styles’ main menu item.
Our more recent Joomla templates include a feature allowing you load the settings used for each of these examples styles. This tutorial will guide you through the process of loading these settings.
  1. From your Joomla administration navigate to your template style settings (Extensions -> Templates -> Styles -> [YourTemplateStyle]).
  2. For this tutorial rather than overwriting your current template settings, we are going to create a new template style in to which we will load the new settings. Enter the Style Name of your choice and hit Save as Copy.
  3. In the Details tab of your newly created template style, select the example style of your choice from the Load Preset dropdown.
  4. Click the Load Preset button. Please note that this option is irreversible. Once this button is clicked the new settings from the preset  will be loaded and saved, overwriting any current settings.
  5. Your new template style has been created with the same settings as the ‘example style’ of your choice.
Note that this only loads the template settings from the example style. It does not load any Joomla content.
