CYBER MONDAY SALE NOW ON - 35% OFF EVERYTHING WITH COUPON CYBERMONDAY
In recent template releases we have added the option to split the main menu dropdown in to multiple columns. This is particulary usefull if you have a large number sub menu items in your navigation which can cause the dropdown to extend outside of the browser window.
This feature allows you to add up to 4 columns in your dropdown and is simple as adding a class name to the 'Link CSS Style' field of dropdowns parent menu item. In the following example we are going to split our dropdown in to 3 columns.
  1. Navigate to your main navigation menu (Menus -> [MainMenu]
  2. Click in to the parent menu item whos sub menu items you organise in to columns.
    119A
  3. Select the 'Link Type' tab. And add columns-3 to the Link Class field. If you already have a class name in this field simply add the columns-3 after it separated by a space. You can also use columns-2 or columns-4 depending on how many columns you wish to implement.
    Note: The Link Class field was previously title Link CSS Style
    119C
  4. Hit Save & Close
    119C
