MENU
  1. giuseppe12345
  3. Saturday, 07 March 2015
how do I change the z-index and the top-margin-top module 2 of the template "RENOVTE", which file I have to edit?
thank you
Can you please provide a link to your site so I can take a look?
yes of course, link
I have to bring more of the module "top-2a."
and I have to fix the z-index because I would like the dropdown menu on the calendar of the booking form would open over the content.
can you help me?
thank you
I hope I was clear in explaining
Okay, this was a lot more difficult than I thought, lol, but try this:
1) The code needs to be entered directly into the Template PHP File, so go to the file /templates/J51_Renovate/index.php and look for the line that shows this:
<div id="container_slideshow" class="container">
2) Place this code directly above that line:
<div width="50%" height="293" scrolling="no" frameborder="0" class="wrapper" style="position:absolute;z-index:2000!important;margin-top: 10%;margin-left: 60%;">
<iframe onload="iFrameHeight()" id="blockrandom" name="" src="http://www.topwebsitetest.eu/booking/prenotazione.html" width="100%" height="293" scrolling="no" frameborder="0" class="wrapper">
</iframe></div>
You can play with the position of it my modifying the margin-top: 10%;margin-left: 60%; portion of the code.
Also, I'm not sure if this is cross-browser compatible or responsive, if you make the changes I'll take another look.
mmmmm no... now I have 2 booking mask...
Right, what you'll want to do is hide the one on the bottom for desktop by using the "hidden-desktop" module class, and add "hidden-phone hidden-tablet" to the new code in the index.php.
This should make it suitable for all devices because the one on the top won't display properly on smaller screens.
This is the best I can do, I tried all kinds of different things and this was the best case scenario, maybe someone else knows a better way.
no, I hope that someone has another solution, how can I contact support?
There is a "Contact Us" link in the footer of this site.
Have you since resolved this issue? Checking your homepage, all booking form dropdowns including your calendar appear to be displaying above all content?
you, that problem was solved thanks.
Now I have the problem that I can not configure any language, because if I go in management extensions, then the language management page is blank ...
what do i do?
