how do I change the z-index and the top-margin-top module 2 of the template "RENOVTE", which file I have to edit?
thank you
- giuseppe12345
- Saturday, 07 March 2015
you, that problem was solved thanks.
Now I have the problem that I can not configure any language, because if I go in management extensions, then the language management page is blank ...
what do i do?
what do i do?
Have you since resolved this issue? Checking your homepage, all booking form dropdowns including your calendar appear to be displaying above all content?
Right, what you'll want to do is hide the one on the bottom for desktop by using the "hidden-desktop" module class, and add "hidden-phone hidden-tablet" to the new code in the index.php.
This should make it suitable for all devices because the one on the top won't display properly on smaller screens.
This is the best I can do, I tried all kinds of different things and this was the best case scenario, maybe someone else knows a better way.
Okay, this was a lot more difficult than I thought, lol, but try this:
1) The code needs to be entered directly into the Template PHP File, so go to the file /templates/J51_Renovate/index.php and look for the line that shows this:
2) Place this code directly above that line:
You can play with the position of it my modifying the margin-top: 10%;margin-left: 60%; portion of the code.
Also, I'm not sure if this is cross-browser compatible or responsive, if you make the changes I'll take another look.
<div id="container_slideshow" class="container">2) Place this code directly above that line:
<div width="50%" height="293" scrolling="no" frameborder="0" class="wrapper" style="position:absolute;z-index:2000!important;margin-top: 10%;margin-left: 60%;">
<iframe onload="iFrameHeight()" id="blockrandom" name="" src="http://www.topwebsitetest.eu/booking/prenotazione.html" width="100%" height="293" scrolling="no" frameborder="0" class="wrapper">
</iframe></div>You can play with the position of it my modifying the margin-top: 10%;margin-left: 60%; portion of the code.
