1. smithjd44
  4. Saturday, 03 September 2016
I am trying to use the J51 Layer Slideshow module from the Ashley Template in the Renovate template.
You can see the result at the link: http://192.185.157.224/~fire/
Is there some css code that I need to add to make the slideshow work correctly or is it not advisable to attempt installing this on the Renovate template website?
Thank you in advance for your assistance!
James Smith
Hi James
.layerslideshow .info > div {
background-color: #555;
.layerslideshow .NextArrow, .layerslideshow .PrevArrow {
height: auto;
margin: 0 5px;
Thank you for the css code for the Layered Slideshow.
The code fixed the background color of the caption box but it didn't help with the missing previous / next arrow.
Do I need to upload into a folder the previous / next arrows files?
Thanks for much for your assistance!
James
Link to website: http://192.185.157.224/~fire/
I was able to fix the issue by adding the following code you mentioned in a previous post in order to load font awesome into the Renovate template.
Added to the Head Custom Code:
<link href="https://maxcdn.bootstrapcdn.com/font-awesome/4.6.3/css/font-awesome.min.css"; rel="stylesheet" integrity="sha384-T8Gy5hrqNKT+hzMclPo118YTQO6cYprQmhrYwIiQ/3axmI1hQomh7Ud2hPOy8SP1" crossorigin="anonymous">
Thanks again for your assistance. Your forums are very helpful and I for one have used it for years to fix issues but more often to further customize your already awesome templates.
I only use Joomla51 templates in my web design work.
James
Hi James
Delighted you were able to find a solution. Thank you for sharing your solution to the forum and for your very kind words! :)
