what is the Upgrade proceedure to Joomla 4 from Joomla 3?
Di I first need to deinstall on J3 and then reinstall in J4 or is there no condlict on J3 and I can just keep the installation?
Regarding your Joomla51 template and modules, simply install them from your Joomla 4 template download via your Extensions Manager after you have migrated to Joomla 4. This will update your template and modules to the Joomla 4 version.
Hi Ciaran, thnx, my first question above about Joomla Upgrade was related only to your extensions. Generally I am informed about Joomla Upgrade but thnx anyway.
Do I have to de-install your news module before upgrading to J4 or can I keep it installed? Will there be no conflict if I keep it on J3 and then upgrade to J4?
