1. Worklive
  3. Tuesday, 19 November 2024
Hi, I would like to show two modules "J51: gridgallery", the first with 4 panes as seen now and the second module at the bottom with only one pane with total width 1100px.
However, if I try to do this, the other 4 tiles above from 532px trasformano turn into 1100px.
How can I do that?
Thank you.
Max
  1. https://www.essentialink.it/choralcreation/index.php/strumenti-esoterici
Hi Max
Just so I understand you correctly, do you wish the last item to be the same width as the first 4?
Hi Ciaran, thanks for your reply.
I need the second module Jrydgallery inserted inside this page to have the width of 1100px
Now you can see that the "Diario digitale" item is a photo, because if I enable the second module with set the size I'm interested in, the other 4 above of the first module also inherit the same size and that's not what I want.
I hope I was able to explain it better...
Would you have a URL to a live example of the issue you wish to solve?
Sure here: https://www.essentialink.it/choralcreation/index.php/strumenti-esoterici
Now I have activated the module I would like of width 1100px
Thank you however this page appears to require login before allowing access.
User: test
Pass: test123er456@
Please I need the problem to be solved as soon as possible.
To amend could you try installing the following update.
Works, thank you!
Hi, I noticed that from mobile the J51 Gridgallery module is shifted to the right by about 15px.
I don't find where to adjust it, I would like this module to look like the component above looks (also same width on mobile).
I attach photos.
Pic 1 link: https://www.essentialink.it/choralcreation/index.php/strumenti-esoterici
Pic 2 link: https://www.essentialink.it/choralcreation/index.php/creazione-entita
Login:
User: test
Pass: test123er456@
Thanks.
Max
Presuming I understand you correctly, to amend try adding the following to the Custom CSS field of your templates parameters (Extensions -> Templates -> [YourTemplateStyle] -> Custom CSS)....
.gridgallery .grid li:first-child {
margin-left: 0 !important;
.gridgallery .grid li:last-child {
margin-right: 0 !important;
Added but did not work, indeed now the first element has shifted slightly while the others have remained the same
Only this page contains this form, in the home I disabled them: https://www.essentialink.it/choralcreation/index.php/strumenti-esoterici
Hi, news?
I await answer to this problem
Here's how you keep seeing that page on my phone
To amend, try also adding the following for mobile display of the gallery (edit to taste)...
margin-left: 15px !important;
