1. Worklive
  3. Tuesday, 19 November 2024
Hi, I would like to show two modules "J51: gridgallery", the first with 4 panes as seen now and the second module at the bottom with only one pane with total width 1100px.
However, if I try to do this, the other 4 tiles above from 532px trasformano turn into 1100px.
How can I do that?
Thank you.
Max
  1. https://www.essentialink.it/choralcreation/index.php/strumenti-esoterici
Hi Max
Just so I understand you correctly, do you wish the last item to be the same width as the first 4?
Hi Ciaran, thanks for your reply.
I need the second module Jrydgallery inserted inside this page to have the width of 1100px
Now you can see that the "Diario digitale" item is a photo, because if I enable the second module with set the size I'm interested in, the other 4 above of the first module also inherit the same size and that's not what I want.
I hope I was able to explain it better...
Would you have a URL to a live example of the issue you wish to solve?
Sure here: https://www.essentialink.it/choralcreation/index.php/strumenti-esoterici
Now I have activated the module I would like of width 1100px
Thank you however this page appears to require login before allowing access.
User: test
Pass: test123er456@
Please I need the problem to be solved as soon as possible.
To amend could you try installing the following update.
Works, thank you!
Hi, I noticed that from mobile the J51 Gridgallery module is shifted to the right by about 15px.
I don't find where to adjust it, I would like this module to look like the component above looks (also same width on mobile).
I attach photos.
Pic 1 link: https://www.essentialink.it/choralcreation/index.php/strumenti-esoterici
Pic 2 link: https://www.essentialink.it/choralcreation/index.php/creazione-entita
Login:
User: test
Pass: test123er456@
Thanks.
Max
Presuming I understand you correctly, to amend try adding the following to the Custom CSS field of your templates parameters (Extensions -> Templates -> [YourTemplateStyle] -> Custom CSS)....
.gridgallery .grid li:first-child {
margin-left: 0 !important;
.gridgallery .grid li:last-child {
margin-right: 0 !important;
Added but did not work, indeed now the first element has shifted slightly while the others have remained the same
Only this page contains this form, in the home I disabled them: https://www.essentialink.it/choralcreation/index.php/strumenti-esoterici
