I'm experiencing a couple of issues with the Clarity template hornav. It could be user error in my setup but I can't tell if it's me, an issue with the template, or an issue with Joomla (running 3.1.1 for the first time). I tried switching to the Oxygen template (installed) and did not experience the same issues so I'm thinking it may be the template???
Issue 1
Most of the main menu items have drop-down lists. When I run my cursor over them, they all expand correctly and I can get them to respond each time I run over them. However, the About Us menu item (2nd hornav position) is intermittent and sometimes non-responsive. It might expand once but after the first time, it won't respond. However, it works correctly if I move it to another hornav position.
Issue 2
Again, the About Us menu item in the 2nd hornav position...
When clicked, it displays the home page article despite having the correct article assigned to it in the back end. I confirmed that the article is assigned correctly by moving the About Us menu item to another position. It displays correctly. I also notice that the URL shows as /index.php rather than http://index.php/about-us.
I tried moving another menu item into the 2nd hornav position (right of "Home"
Could you please take a look at both these issues and let me know if you can tell where the error is?
Thank you... Dianne
PS -- I'll send you a login for Admin access via email. I'll reference this post.
