1. dlw1433
  3. Wednesday, 08 May 2013
I'm experiencing a couple of issues with the Clarity template hornav. It could be user error in my setup but I can't tell if it's me, an issue with the template, or an issue with Joomla (running 3.1.1 for the first time). I tried switching to the Oxygen template (installed) and did not experience the same issues so I'm thinking it may be the template???
Issue 1
Most of the main menu items have drop-down lists. When I run my cursor over them, they all expand correctly and I can get them to respond each time I run over them. However, the About Us menu item (2nd hornav position) is intermittent and sometimes non-responsive. It might expand once but after the first time, it won't respond. However, it works correctly if I move it to another hornav position.
Issue 2
Again, the About Us menu item in the 2nd hornav position...
When clicked, it displays the home page article despite having the correct article assigned to it in the back end. I confirmed that the article is assigned correctly by moving the About Us menu item to another position. It displays correctly. I also notice that the URL shows as /index.php rather than http://index.php/about-us.
I tried moving another menu item into the 2nd hornav position (right of "Home";) and the results are the same. Ex. I put Quality Mentoring in that position and it displayed /index.php.
Could you please take a look at both these issues and let me know if you can tell where the error is?
Thank you... Dianne
PS -- I'll send you a login for Admin access via email. I'll reference this post.
Hi again.
I just noticed something else...
If I click through the pages from right to left, when I reach About Us, it displays correctly... sometimes. Then it reverts to being non-responsive and going to the /index.php page.
Strange?
... Dianne
Hi Dianne
The logo area of your template was overlapping some of the menu items to the left. We amended this by adding the following to the Custom CSS field of your templates parameters...
[code type=css].logo_container, h1.logo, h1.logo a {
width: 270px;
}[/code]
