1. Kliekske
  3. Monday, 24 July 2023
I'm using the Natalie template. In position header 2 I want to show a top menu for menu-items that are less important.
But the top menu doesn't show when there is a slideshow active in the showcase position. (which is on every page)
For the slideshow I'm using the J51_LayerSlideshow module.
Is there a way to fix this?
Joomla version: 4.3.3
PHP version: 8.0.28
Thanks for the support!
Best regards, Frits Strijbos
  1. http://nieuw.kieveloeet.nl/
Hi Frits
This doesn't solve your current issue, but for less important menu items (Data Privacy, Legal Notes, Contact, ...) I usually use an additional menu at the footer of the page. Here is an example: https://sutbaselgia14.de/index.php.
You might consider a similar solution.
Rolf
Disabling the option makes the top menu visible. So problem is solved.
Thanks for the great support!
Hi Frits
