1. Forrest Gump
  4. Friday, 28 January 2022
I use the template Sophia and the J51_ImageHover modules.
If "reject"/"not accepted" is selected via the cookie blocker, the Hoover animations will no longer run. Could this be due to an old JQuery version described here? (https://joomla51.com/forum/kodaline-cookiebot-consent-blocks-mobile-main-menu)
Or is there another solution?
Update:
I´ve intalled the jQueryEasy, but without success.
I use CookieHint from redim. There are two options for the cookie blocker
- only cookies
- Cookies and external sources
If I only select cookies the modules work, if I select the second one it doesn't work.
Is there a way to select "Cookies and external sources" and the modules still work?
Thanks & greetings
here is the link.
The following setting is selected at the moment in Reim CookieHint-Cookieblocker
If I select accept cookies and look at the cookies in Chrome, a letter/number combination is displayed next to the redim cookie - where does that come from?
Thanks again!
Your cookie extension appears blocking a number of your module CSS due to a content security policy. This appears to be effecting most of your modules including some non Joomla51 examples.
I am not familiar with this extension so I would be unable to state what such a number means. Maybe consult their documentation?
Hi, thanks for checking
