1. accipiter
  4. Monday, 18 September 2017
I found some small problem with London template:
1) I added other two links in the horizontal side bar over the slideshow. Thus the sidebar is developing in two rows:
I'd like all links are in one row.
2) I saw that the images in the slide show don't resize correctly. If I see the slideshow with a desktop computer o a notebook.
I tried to upload images with resolution 1800 x 800 or 1350 x 600.
If the images work very well for desktop computer they don't work for the notebook and the opposite.
OK for mobile version.
3) I published 3 small modules in bottom-3a position. They works very well in desktop version.
Every each letter appears vertically aligned in the mobile version.
The web site is off line. My I send you the admin keys?
I'll be grateful for your help.
Thank you very much.
Regartds
Andrew
I tell you that I solved also the second problem.
I took the "Max Height" in the settings of "Homepage Slideshow" module from 600 to 800.
It is work very well.
Every thing is Ok.
Andrew
Hi Andrew
May I suggest sending temporary administration access to your Joomla installation to [email protected] and we will examine these issues further. For our reference please paste a link to this post in your email.
1. To amend try adding the following to the Custom CSS field of your templates parameters...
.hornav > ul > li > a {
padding: 25px 10px;
2. Unless I misunderstand you, it appears we are unable to replicate this issue. Could you please provide a screenshot of the issue you are having?
3. Thank you for bringing this issue to our attention. This issue should be now resolved.
here is the screen shot. http://bit.ly/2jOajdA
I hope this'll may help you:
Andrew
PS the solution to "To amend try adding the following to the Custom CSS field of your templates parameters..." is working very weel! Thanks :)
