1. accipiter
  4. Monday, 18 September 2017
I found some small problem with London template:
1) I added other two links in the horizontal side bar over the slideshow. Thus the sidebar is developing in two rows:
I'd like all links are in one row.
2) I saw that the images in the slide show don't resize correctly. If I see the slideshow with a desktop computer o a notebook.
I tried to upload images with resolution 1800 x 800 or 1350 x 600.
If the images work very well for desktop computer they don't work for the notebook and the opposite.
OK for mobile version.
3) I published 3 small modules in bottom-3a position. They works very well in desktop version.
Every each letter appears vertically aligned in the mobile version.
The web site is off line. My I send you the admin keys?
I'll be grateful for your help.
Thank you very much.
Regartds
Andrew
I tell you that I solved also the second problem.
I took the "Max Height" in the settings of "Homepage Slideshow" module from 600 to 800.
It is work very well.
Every thing is Ok.
Andrew
here is the screen shot. http://bit.ly/2jOajdA
I hope this'll may help you:
Andrew
PS the solution to "To amend try adding the following to the Custom CSS field of your templates parameters..." is working very weel! Thanks :)
1. To amend try adding the following to the Custom CSS field of your templates parameters...
.hornav > ul > li > a {
padding: 25px 10px;
2. Unless I misunderstand you, it appears we are unable to replicate this issue. Could you please provide a screenshot of the issue you are having?
3. Thank you for bringing this issue to our attention. This issue should be now resolved.
Hi Andrew
May I suggest sending temporary administration access to your Joomla installation to [email protected] and we will examine these issues further. For our reference please paste a link to this post in your email.
