1. Timer
  3. Friday, 11 August 2017
Hello! I have to use a "Carousel" module on my site, but the module height is too small. This modul looks very different on your demo "J51 - Beaumont" website. What can I do for same result?Primarily, I would like more space (height) under the picture!
Thank you for your reply!
  1. http://www.vodicenyar.hu/index.php/apartmanok
Just to confirm that I understand you correctly, you are trying to replicate the 4 images next to the Build Something Beautiful! text on our demo (http://www.joomla51.com/demo/0131/)? Note that these images are created using the J51 GridGallery module rather than the J51 Carousel module.
Hello!
No, I would like achive same design:
http://www.joomla51.com/demo/0131/index.php/features/carousel-module
To resolve try setting the Columns Per Slide field of your module settings to 3.
  3. # 3
Doesn't working... :(
But, if I set to enable the "Box column" option, I got beautiest result.
  3. # 4
If you wish you can send temporary administration access to your Joomla installation to [email protected] and we will set up the carousel for you similar to that of the template demo. For our reference please paste a link to this post in your email.
  3. # 5
Thank you for your suggestion! The current result is good enough for me at the moment, but later I can ask for your help!:)
Regards,
Timer
  3. # 6
