1. dautrich
  4. Sunday, 05 March 2023
In SKYLAR_J4's template configuration, there is an option to set the Mobile Menu Title under "Responsive Options" (s. SKYLAR_Header_Mobile_Menu_Backend.jpg, marked in red). But regardless of what's entered here, the site will display "Menu" in the mobile main menu (s. SKYLAR_Header_Mobile_Menu_Frontend.jpg).
There is a temporary solution:
  • Edit file templates/j51_skylar/js/mmenu-light.js
  • Search for "Menu" (including the apostrophes)
  • Change "Menu" to "Your_Main_Menu_Title"
The problem with this temporary solution: It has to be re-applied OnAfterTemplateUpdate ;)
Rolf
  1. https://systemtest.hasenritter.de
Hi Rolf
Hi Rolf
Thank you for bringing this issue to our attention.
I have just created an update for this template which includes a fix for this issue. I have also applied the fix to your Joomla installation.
I have installed the new SKYLAR_V4 V1.1.8 on the site. It fixes the issue. :)
I assume that you don't need access to my site for the moment. Therefore, I have re-established the .htaccess password on the admin directory. I also disabled your superuser account.
Thx and regards
Rolf
