1. dautrich
  4. Sunday, 26 July 2020
How can I achieve to see the Skylar CLASSes from within JCE (free edition)?
Of course I can insert the CLASS entry into the generated code. But there should be an easier way to do it.
Would you have an example of the class you are referring to?
I would like to add the classes from your template to <p> or <div>, i.e. the following classes:
  • <em class="highlight yellow">
  • <div class="columns-2">
  • <div class="columns-3">
Admittedly I am not overly familiar with the JCE Free Editor. I do believe you can use the Insert/Edit Atttributes option to add classes to a paragraph however I believe this does not extend to other elements, in particular divs.
Thanks, that helps for <p>-Tags!
