Hi there,
I was just wondering if there was a way of adjusting the width of the component and side cols combined so that the outer edges of the side cols line up with the sides of the Sideshow image above and the footer modules etc below? I have attached an image as an example.
My template width is 1070 to accomodate the banner image and the image hover link images which are 315 px wide. The module widths for Bottom 1a, 1b and 1c are set to 33%.
Side col-a width is 25 and side col-b width is 20.
The only way I could set the template so the side cols lined up with the rest of the content was to make the template width narrower, which then in turn cropped the image hover link images.
Not a major problem as I guess I could make the image hover link images smaller and readjust the template width to a narrower setting, but i was trying to get them to take up the entire width of the bottom module and they didn't when they were the smaller size.
Please can you advise if there is any other way?
- pearlyjones
- Wednesday, 12 November 2014
