Hi Ciaran, hi all,
I'm trying to set up my new homepage with the Serenity Template.
The Icon Module has been moved from top-2a to bottom-3a. I also changed the background color for bottom-3a, but this change is not applied. The background color is still the same as bottom-2, and if I change bottom-2 the background of bottom-3 also changes.
When I try to set a Module Override, it's not possible to choose bottom-3a because the dropdown menu ends with Bottom-2E.
Can you help, please?
Kind regards
Anja
