1. Fuhrbach
  3. Monday, 27 May 2019
Hi Ciaran, hi all,
I'm trying to set up my new homepage with the Serenity Template.
The Icon Module has been moved from top-2a to bottom-3a. I also changed the background color for bottom-3a, but this change is not applied. The background color is still the same as bottom-2, and if I change bottom-2 the background of bottom-3 also changes.
When I try to set a Module Override, it's not possible to choose bottom-3a because the dropdown menu ends with Bottom-2E.
Can you help, please?
Kind regards
Anja
Hi Anja
Thank you for sharing your solution and for bringing these issues to our attention.
I have just updated the Serenity template amending each of these issues (background field and overrides dropdown).
thank you.
I solved the problem this morning by myself.
The article would not have helped me (I was there and tried to change the settings of the page, but it was not possible).
The bug was solved by some additional lines.
template/xyz/elements/moduleOverrides.xml
Under
<option value="bottom-2e">Bottom-2E</option>
I added:
<option value="bottom-3a">Bottom-3A</option>
<option value="bottom-3b">Bottom-3B</option>
<option value="bottom-3c">Bottom-3C</option>
<option value="bottom-3d">Bottom-3D</option>
<option value="bottom-3e">Bottom-3E</option>
Does the following article help on this issue?... https://www.joomla51.com/tutorials/troubleshooting/template-options-not-effecting-frontend
If not, may I suggest sending temporary administration access to your Joomla installation to info@joomla51.com and we will examine this issue further. For our reference please paste a link to this post in your email.
