Good evening.
Firstly thank you for your reply. But because I do not know hardly any English, obviously do not understand.
I explain the two Screenshot.
I remember from another templete, that we did this with a code change in custom css.
Presuming you are using Joomla 3.x and it is with a 'Cateogry Blog' menu item you can try adding the following to the Custom CSS field of your templates parameters where #cccccc is your background color (edit to taste)..
Just this, my dear friend!
When you have time, tell me, this template LifeStyle, I bought it with 19€. or should I get the version with the 69€ if I remember correctly?
However, thank you very much!
