1. vag
  3. Saturday, 23 August 2014
I want to break the two articles as being separate boxes one by the other. Is that possible?
thank you very much.
Any further queries please feel free to post them here on the forum :)
Ok friend! :)
I hope if I need your help in the future to bother you again I guess...?
Best wishes.
Again thank you!
If you just wish to use the 'Lifestyle template then you just need to spend €19. A €69 subscription will allow you access to use all of our templates :)
Just this, my dear friend! :)
When you have time, tell me, this template LifeStyle, I bought it with 19€. or should I get the version with the 69€ if I remember correctly?
However, thank you very much!
Hi Vag
Ok I think I understand :)
Presuming you are using Joomla 3.x and it is with a 'Cateogry Blog' menu item you can try adding the following to the Custom CSS field of your templates parameters where #cccccc is your background color (edit to taste)..
.blog .item, .leading-0, leading-1, leading-2 {
background: #cccccc;
padding: 20px;
Good evening.
Firstly thank you for your reply. But because I do not know hardly any English, obviously do not understand.
I explain the two Screenshot.
I remember from another templete, that we did this with a code change in custom css.
Thank you very much for your help!
Have you tried using tehe 'Category Blog' menu item and setting it to 2 columns? For details you can check out the following tutorials...
http://joomladetroit.com/joomla-tutorials/how-to-set-up-a-blog-in-joomla
http://docs.joomla.org/Help25:Menus_Menu_Item_Article_Category_Blog
