A search field can be created by navigating to Extensions -> Modules -> New -> Search. This module can then be assigned to the module position of your choice.
We are unable to locate the suggested CSS in your source. May I suggest sending temporary administration access to your Joomla installation to info@joomla51.com and we will examine this issue further. For our reference please paste a link to this post in your email.
I have added the suggested CSS to your homepage template style and your homepage search field is now displaying on all devices. For easier maintenance it is always a good idea to remove any template styles you are no longer using (Extensions -> Templates -> Styles).
