Hi. Cant seem to find a SEARCH FIELD for the Harmony Template?
Visitors should have the possibility to serach the articles/blogs
Search field for Harmony
- Issue
- NoNameAtAll
- Sunday, 11 February 2018
A search field can be created by navigating to Extensions -> Modules -> New -> Search. This module can then be assigned to the module position of your choice.
Thank you... I didn't ask the right question - search works fine on web version, but cant be found on mobile device version. Any ideas?
It's on the mobile device my customer needs an search options. See attachment.
.header-1, .header-2 {
display: block !important;
}Ciarán
Thanks for the quick answer... unfortunately that didn't do the trick. Where do i control what is visible on mobile devices?
http://yvonneluffgottfredsen.dk/
Is the homepage... It has a search field. It is the mobile device that is missing a searchfield.
Martin
Martin
- # 9
Thank you Martin
We are unable to locate the suggested CSS in your source. May I suggest sending temporary administration access to your Joomla installation to info@joomla51.com and we will examine this issue further. For our reference please paste a link to this post in your email.
- # 10
Thank you Martin
I have added the suggested CSS to your homepage template style and your homepage search field is now displaying on all devices. For easier maintenance it is always a good idea to remove any template styles you are no longer using (Extensions -> Templates -> Styles).
- # 12
