1. mediafrog
  4. Friday, 20 May 2016
hi ciaran,
I have some problems to open videos on the smart phone, and I got this message from the developer
Video doesn't open, because there is a javascript error on your website not related with our extension.
http://screencast.com/t/lbqfVcXzI
This conflicting script probably comes from your joomla template as it's not included along with all other script. There is a declaration of not existing function, so you need to remove this code from your template and video will work correctly.
http://screencast.com/t/MsllBAp2
I have removed the code, but the videos on my smarthone doesn't work well.
http://www.meti-coaching.de/joomla-neu/videos#
maybe there is a solution, so I can use this videogallery?
regards grit
Hi Grit,
on my Lumia 640 XL LTE I have no problems opening the videos. Your side is working and looking just perfect.
Regards,
Marek
Hi Grit
Also tested on a Samsung S5 and an iPhone 6+ without any issues.
