Originally the Scarlett LayerSlideshow module used the Joomla 'Repeatable' subform (
https://docs.joomla.org/Repeatable_form_field_type). The is that this form has been deprecated and is been replaced by
https://docs.joomla.org/Special:MyLanguage/Subform_form_field_type
Updating your module to use the new subform field mean all your field information will be lost and you will need to re setup each module. Normally this wouldn't be a huge issue however you have quite a few of the.
Alternatively we can replace the image field with a text field and you set the images manually? This would mean old field information would not be lost.
