1. jmuehleisen
  3. Wednesday, 31 October 2012
I am working on a 2.5.7 site using Revelation here:
http://ojgreenhorizon.com/uci/
Look at the top menu item titled "Departments."
There are 2 sub-menu items: Clinical Services Team and Management Support Team.
On the "Management" sub-menu I am able to select the sub-sub menu items with no problem.
But on the "Clinical Services Team" sub-menu ... I cannot choose the sub-sub menu items at all. The sub-sub menu disappears as the mouse approaches it.
I've tested this in Chrome and IE and confirm the behavior on both.
I've adjusted the order on these two (flipping the order) and have the same behavior.
Any insight on this would be appreciated!
John
That's great.
Always glad to help.
Ciarán,
Thank you for the updated template.
I have installed that and it resolves the issue with the sub-sub-menus.
Thanks again for your assistance.
John
Hi jmuehleisen
There is an update to the template that will amend this issue. For the Joomla 2.5 version of the template please forward your PO number to info@joomla51.com and we will reply with the latest version of the template.
Further to this issue, I notice another problem with the sub-sub menus.
When a sub-sub menu is visible, moving the cursor along the sub-menu item causes a flicker in the various sub-sub-menus that "fly out."
With the URL I gave above: http://ojgreenhorizon.com/uci if you hover the cursor above "departments" the 2 sub-menu items appear properly ("Clinical" and "Management."
If you hover the cursor over "Clinical Services" the sub-sub-menu flies out properly.
No problem here.
But, if you hover cursor over "Management Support Team" the sub-sub-menu for this flies out, but as you move the cursor (still over the words "Management Support Team" the sub-sub-menu for "Clinical Services" then flies out, then the "Management Support Team" sub-sub-menu flies out almost immediately. Each cursor move (even though still over the same sub-menu item) causes this behavior.
Any insight you can give on this would be appreciated.
John
NB: The template version is 1.0 ... not sure if there has possibly been an update to this template or now.
Thanks for the quick reply.
I did not have the "moomenu" Menu Tag ID in there, and by adding that, the "Clinical Services Team" menu is now available.
Thanks for your help!
John
Hi jmuehleisen
Ensure you have the menu module set up correctly in particular adding moomenu to the Menu Tag ID field of the menu modules parameters (Extensions -> Module Manager ->[YourMenuModule])
