1. smithjd44
  4. Thursday, 07 April 2022
I am using the Joomla 4 version of Everly and what I have is a very narrow view of the slideshow on the mobile view.
Do you have custom CSS coding that would restore the correct height of the slideshow on the mobile view?
The website is located on the domain http://tempdomain68.site
Thank you for your assistance!
James
  1. http://tempdomain68.site
Hi James
In the LayerSlideshow module settings, try setting the Overlap Header if in showcase-1# module position option to No.
I am using demo content to start building the website and the Overlap Showcase 1# is set to No.
I am trying to restore the height of the mobile view slideshow so I can install the Advanced Module extension so I can display the title text in a mobile version of the slideshow.
As always, I appreciate the assistance!
James
Hi James
Presuming I understand you correctly, try adding the following to the Custom CSS field of your templates parameters (Extensions -> Templates -> [YourTemplateStyle] -> Custom CSS)....
@media only screen and ( max-width: 1180px ) {
#container_showcase1_modules + .content_main {
margin-top: 0 !important;
That worked perfectly except when I made use of the Advanced Module Manager to create a mobile version of the slideshow using the paragraph for the title caption, it is showing a narrow caption which cuts off a portion of the caption.
I am using the same Advanced Module Manager for my website https://starlightwebdesign.com where the mobile caption works great but not on the website that I am working on at the domain http://tempdomain68.site.
If you check out both websites you can see what is happening on the http://tempdomain68.site vs the https://starlightwebdesign.com website.
Again, I appreciate all of the custom CSS coding you have provided in the past.
This is a great service that Joomla51 offers its customers!
James
  1. https://starlightwebdesign.com
  2. http://tempdomain68.site
Hi James
To amend try replacing the suggested CSS with the following which should give you a lot more space on smaller screens for the caption text (edit to taste)...
.layerslideshow .info {
padding-left: 0;
padding-right: 0;
font-size: .5em;
padding-bottom: 0;
