I'm trying to assign a custom module to the Top 3A module position. Unfortunately nothing appears. If I select the Top 2A position it works just fine. Do you know where could be the issue ? I believe I've installed the latest version of the template.
When browsing the index.php file I don't find any reference to the Top 3 positions. Might this be the cause ?
Thanks for your help,
Peter
