1. wisobe
  3. Sunday, 06 January 2019
I'm trying to assign a custom module to the Top 3A module position. Unfortunately nothing appears. If I select the Top 2A position it works just fine. Do you know where could be the issue ? I believe I've installed the latest version of the template.
When browsing the index.php file I don't find any reference to the Top 3 positions. Might this be the cause ?
Thanks for your help,
Peter
Thanks for your reply. It's weird those positions are offered in the backend but they are not. Anyway, I tried your suggestion to use another template style and it worked like a charm. Thanks. :-)
Best regards,
Peter
Thank you Peter
I am sorry to say our Renovate template does not include a top-3# module position (https://www.joomla51.com/demo/0105/index.php/features/module-positions). My apologies for remembering this initially.
Considering your reasons for needing a top-3# position mentioned in your email, may I suggest the following article which should offer you a work around... https://www.joomla51.com/tutorials/joomla-basics/creating-multiple-template-styles
Hi Peter
