1. scherr
  3. Monday, 16 December 2013
I like the grid gallery a lot (in fact it was one of the reasons to buy the renovate template). Using the modules backend it´s ony possible to link to Menu-Items, which is a quite unpleasant restriction. Is it possible to directy link to an article with a hack? Maybe this would be a good feature for future versions. I guess most people will use this as a teaser for articles and not for menu items.
To change the 'menu item' field to a text field allowing you to add the URL of your choice open up your modules mod_j51gridgallery.php (../modules/mod_j51gridgallery/mod_j51gridgallery.xml) and replace each instance of the following....
type="menuitem"
with....
type="text"
In your modules default.php (../modules/j51_gridgallery/tmpl/default.php) try replacing the following (approx. line 126)...
<a href="/<?php echo JRoute::_("index.php?Itemid={$image_url[$cur_img]}") ?>" target="<?php echo $target_url[$cur_img]; ?>" >
with...
<a href="/<?php echo $image_url[$cur_img]; ?>" target="<?php echo $target_url[$cur_img]; ?>" >
You can then add a URL rather than selecting a menu item for each image.
is there a possibility in addition to link to an external page and open this in a new tab in the browser?
To do so you can replace in the above code...
Replace with..
<a href="/<?php echo $image_url[$cur_img]; ?>" target="_blank" >
Just after the link (text) you can also set the following: " target="_blank.
In this way, you can leave the image links on the same site and open the textlinks in a new window.
In the J51Gridgallery wich is in the Habitat template, there is no space to place the Link.
How can i place an external link?
Hello Edgar,
see the second post in this thread, made bij Ciaran.
I have tried this solution but I only get a 404-page when clicking the gridgallery.
May I suggest sending temporary FTP and administration access to your Joomla installation to info@joomla51.com and we will examine this issue further. For our reference please paste a link to this post in your email.
Hi !
I did try this, but I only get this error message:
Error: Call to undefined method Joomla\CMS\Document\ErrorDocument::countModules(): Category not found
I did check twice, Im pretty sure the modifications was alright, but Im using Calibra Grid Gallery (dunno if its suppose to make a difference)
Any idea ? :O
Hi David
