How could I change the size of top and bottom padding of a module (Top-1) in "Renita" so the hight is "smaller"?
I don't want to use the "Remove Container Padding" because it also remove the right and left padding.
Have you considered using the Module Style Overrides option in your template settings. This will allow you to set a new top and bottom padding for each of your modules.
Hi.
Sorry, I was gone for a while and didn't take time to answer...and forgot.
I did try the "overrides", but it didn't do exactly what I wanted (still to "high" on the bottom one)), but that will do.
Thank you for your answer/time.
