1. DamsStChristophe
  3. Friday, 29 June 2018
Hi there.
How could I change the size of top and bottom padding of a module (Top-1) in "Renita" so the hight is "smaller"?
I don't want to use the "Remove Container Padding" because it also remove the right and left padding.
Thank you.
Hi.
Sorry, I was gone for a while and didn't take time to answer...and forgot.
I did try the "overrides", but it didn't do exactly what I wanted (still to "high" on the bottom one)), but that will do.
Thank you for your answer/time.
Have you considered using the Module Style Overrides option in your template settings. This will allow you to set a new top and bottom padding for each of your modules.
