I want to reduce the white space between the text and the slideshow.
It's huge now. How can I fix that?
website
https://prnt.sc/r4ix2v
Thanks in advance,
Edgar
- Edgar68
- Wednesday, 19 February 2020
yes after a long search I found the issue, there was 1 image in the slider which was a different size.
Sorry for bothering you.
Thanks anyway,
Edgar
Thanks anyway,
Edgar
Hi Edgar
Have you since found a solution to this issue? Your screenshot is showing a bigger space than what is on your website.
It seems very strange. I see nothing in your site markup that can cause extra space below your slideshow and unable to replicate. A shot in the dark but could you try using the attached 'lite' version of the LayerSlideshow. This extension includes all the features you are currently using.
thanks for the excellent support.
The solution was this LayerSlideshow lite!
The problem is solved now.
Thank you very much,
Edgar
Edgar
Hi Edgar
.showcase-1 .module_surround {
padding-bottom: 0;
}Ciaran
sorry but the problem is still there.
I saw when I have 4 images into the slideshow, everything runs normally.
But when I add 1 more, white space is there !!
Edgar
Edgar
I tried again, but there seems to be a problem with different browsers.
https://prnt.sc/r5qkyi > Chrome
https://prnt.sc/r5r1o3 > Firefox
https://prnt.sc/r5qpnc > Brave
https://prnt.sc/r5qrd9 > Opera
Can you help me to solve this problem?
Edgar
Edgar
I added it to the custom CSS field.
Edge | Firefox | Opera is ok!
Now the problem is only in Brave | Chrome
Both like this > https://prnt.sc/r5wd0n
I tried something:
When I have 4 images in the slideshow, space is gone, but when I have 5 or 6 images in the slideshow, there is the whitespace again.
And the images are all the exact size!
Edgar
I tried something:
Edgar
Hi Edgar
Have you since been able to resolve this issue? I have checked your site in both Chrome and Brave and they each display the same as Firefox.
- # 9
No, the problem isn't solved with the joomla51 slideshow.
I just added another Slide into my website to look if it works, and it works with another slideshow. (FAV slider)
But my whole website is with Joomla51 components, so it just should work.
I hope there is a fix for it.
Edgar
Edgar
- # 10
Hi Edgar
Our issue is that we can not replicate your problem on every browser available to us (Chrome, Canary, Firefox, FF DevEd and Edge). Can you confirm that you have cleared your browser cache?
- # 11
I just cleared my browser again.
But I still have the problem with Chrome, Canary, Brave & Opera.
On Firefox and Edge, everything is ok.
Edgar
Edgar
- # 12
