Hello there,
I approached two problems with the module:
On "circular" styles, "value color" is not applied.
On "horizontal" styles, "bar color" is not applied.
Switching back to "default color" does not change anything. I guess it is overwritten by something?
Link to website: https://www.bayern-furs.de/projekte
Thanks for your assistance!
-Chris
- FallenWolf
- Wednesday, 29 April 2020
Oh wow, whatever you did, it worked!
The only thing remaining is the font size, it seems to be too large when something reaches 100% (overlaps on "circular"
Okay, I noticed two minor problems:
- On "horizontal", the bar is shortened immediately before it turns to 100%
- On "circular" the "%" overlap the number at 100%
It's not too bad, but it doesn't really look professional though.
Additional information:
I now noticed that the font size is not applied as well, so the whole style of the text does not fit at all - even if the "inspect" tool of chrome says different.
Thankful for any help!
Hi Chris
Would you have a URL to an example of the progress bar issue? I am creating an update for the module and I wasnt to ensure all issues will be resolved.
Hi Chris
Hey Ciaran,
sure, it's the one i linked in the first post: https://www.bayern-furs.de/projekte (should be visible now).
-Chris
Hi Chris
Does this URL also include and example of the "On "horizontal" styles, "bar color" is not applied." issue?
Hi Chris
I added it at the bottom of the page a second ago
Hi Chris
We have just updated the Progress module. This update can be obtained via Profile -> Extension Downloads and should resolve each of your issues. Keep us posted!
I have just updated the Progress module, hopefully resolving these issues.
- # 10
Sounds good
Is the update yet online? It says "Updated: 30-Apr-2020" so I think it's still the old version (as nothing changed as far as I can spot it by now)?`
-Chris
- # 11
The first update increased the distance between the value and % symbol. I have refactored to be inline elements so should now work regardless of the font used. (v.1.1.4 - available va 'Extension Downloads').
We have been unable to replicate the progress bar issue so were taking a bit of a shot in the dark regarding a fix. If this is a serious issue for you, may I suggest sending temporary administration access to your Joomla installation to info@joomla51.com and we will examine this issue further. For our reference please paste a link to this post in your email.
- # 14
