Hello there,
I approached two problems with the module:
On "circular" styles, "value color" is not applied.
On "horizontal" styles, "bar color" is not applied.
Switching back to "default color" does not change anything. I guess it is overwritten by something?
Link to website: https://www.bayern-furs.de/projekte
Thanks for your assistance!
-Chris
- FallenWolf
- Wednesday, 29 April 2020
The first update increased the distance between the value and % symbol. I have refactored to be inline elements so should now work regardless of the font used. (v.1.1.4 - available va 'Extension Downloads').
We have been unable to replicate the progress bar issue so were taking a bit of a shot in the dark regarding a fix. If this is a serious issue for you, may I suggest sending temporary administration access to your Joomla installation to info@joomla51.com and we will examine this issue further. For our reference please paste a link to this post in your email.
I have just updated the Progress module, hopefully resolving these issues.
Sounds good
Is the update yet online? It says "Updated: 30-Apr-2020" so I think it's still the old version (as nothing changed as far as I can spot it by now)?`
-Chris
Okay, I noticed two minor problems:
- On "horizontal", the bar is shortened immediately before it turns to 100%
- On "circular" the "%" overlap the number at 100%
It's not too bad, but it doesn't really look professional though.
Oh wow, whatever you did, it worked!
The only thing remaining is the font size, it seems to be too large when something reaches 100% (overlaps on "circular"
Hi Chris
We have just updated the Progress module. This update can be obtained via Profile -> Extension Downloads and should resolve each of your issues. Keep us posted!
- # 9
Hi Chris
Does this URL also include and example of the "On "horizontal" styles, "bar color" is not applied." issue?
I added it at the bottom of the page a second ago
- # 10
Hi Chris
- # 11
Hi Chris
Would you have a URL to an example of the progress bar issue? I am creating an update for the module and I wasnt to ensure all issues will be resolved.
Hey Ciaran,
sure, it's the one i linked in the first post: https://www.bayern-furs.de/projekte (should be visible now).
-Chris
- # 12
Hi Chris
- # 13
Additional information:
I now noticed that the font size is not applied as well, so the whole style of the text does not fit at all - even if the "inspect" tool of chrome says different.
Thankful for any help!
- # 14
