Hello Ciarán,
I have some problems with the LIFESTYL template.
1. I get no slideshow. First I have installed the slideshow which was in the ZIP file of the template. Then I got an error.
Error message: ...\modules\mod_j51slideshow\mod_j51slideshow.php on line 19
Then I have installed the new slideshow from your homepage: free-module-extensions.
Now there is no error message, but also none slideshow.
2. The next problem makes the Thumps Gallery. I can not see any pictures.
3. If the Thump Gallery is enabled then the Carousel don´t work. Is the Thump Gallery deactivated the Carousel runs. What is the problem?
The administration access to my Joomla installation I have send to you ([email protected]) and a link to this post.
Thanks a lot!
Helmut
