Warning
JUser: :_load: Unable to load user with ID: 47182
  1. Bugsys
  3. Thursday, 23 February 2017
Hello Ciarán,
I have some problems with the LIFESTYL template.
1. I get no slideshow. First I have installed the slideshow which was in the ZIP file of the template. Then I got an error.
Error message: ...\modules\mod_j51slideshow\mod_j51slideshow.php on line 19
Then I have installed the new slideshow from your homepage: free-module-extensions.
Now there is no error message, but also none slideshow.
2. The next problem makes the Thumps Gallery. I can not see any pictures.
3. If the Thump Gallery is enabled then the Carousel don´t work. Is the Thump Gallery deactivated the Carousel runs. What is the problem?
The administration access to my Joomla installation I have send to you (info@joomla51.com) and a link to this post.
Thanks a lot!
Helmut
Thank you Helmut
1. I have installed your slideshow module manually and it should now be functioning correctly.
2. To resolve ensure that the file extensions of your gallery images are in lowercase and that no spaces are used in the filename. ('my-image.jpg' instead of 'my image.JPG').
3. Sorry to say at present our Thumbs Gallery module is not designed to be contained within a carousel.
