1. manusha
  3. Wednesday, 28 March 2018
Hi, I tried to install the templates following the Installing Joomla Documentation, but when i go to install by browser web, I get this answer: "No configuration file found and no installation code available. Exiting..."
I'm not a beginner in the installation of joomla sites
  1. http://www.paramarta.it
On further examination this is definitely an issue with the template. My sincere apologies for the inconvenience.
I have re built and tested the template demo installer and and it is now working without issue. To obtain simply redownload your template from your Joomla51 My Downloads.
Confirmed that the Kaylee demo-installer fails. The installation folder is empty except for one sql file.
Ok! I could only proceed like this: I installed a version standard of Joomla3 and then I made the upload of l51_Kaylee.zip. Unfortunately a directly installation of j51_Kaylee_Demoinstaller (as I hoped) failed
It sounds like your configuration.php file has been removed/renamed. This file should be in the root of your Joomla folder after installation is complete?
