1. manusha
  3. Wednesday, 28 March 2018
Hi, I tried to install the templates following the Installing Joomla Documentation, but when i go to install by browser web, I get this answer: "No configuration file found and no installation code available. Exiting..."
I'm not a beginner in the installation of joomla sites
  1. http://www.paramarta.it
It sounds like your configuration.php file has been removed/renamed. This file should be in the root of your Joomla folder after installation is complete?
Ok! I could only proceed like this: I installed a version standard of Joomla3 and then I made the upload of l51_Kaylee.zip. Unfortunately a directly installation of j51_Kaylee_Demoinstaller (as I hoped) failed
Confirmed that the Kaylee demo-installer fails. The installation folder is empty except for one sql file.
On further examination this is definitely an issue with the template. My sincere apologies for the inconvenience.
I have re built and tested the template demo installer and and it is now working without issue. To obtain simply redownload your template from your Joomla51 My Downloads.
