1. silvias1963
  3. Monday, 26 December 2016
(Sorry, i cant' speak english...) :(
Hi, i use the Template "Ashley" in 2 Installation. In the first installation lookes the Main-Menue very good. See here: http://hokineu.striewski.biz
In the second installation (we have changed the server), the Main-Menue lookes wrong. The title-attribute shall not be seen to every time. But only as a tool-tip (as in the first installation). Here is the second installation with the problem: http://www.hoffnungskirche-herten.de
Can you help correct the error?
Regards, Silvia Striewski
  1. http://www.hoffnungskirche-herten.de
To disable the subtitle display try adding the following to the Custom CSS field of your templates parameters...
.hornav > ul > li > a::after {
display: none;
.hornav > ul > li > a {
padding-bottom: 0;
We have made some changes to your top menu styling to better accommodate your menu items.
Thank you!
It looks better. :D I would prefer it so: http://hokineu.striewski.biz Without title-attributes in the first view. And the title-attribute only s a tool-tip.
If it is not possible, then it can still remain so.
Thank you for your help.
LG, Siliva
Thank you for your help very much!
LG, Silvia
