1. silvias1963
  3. Monday, 26 December 2016
(Sorry, i cant' speak english...) :(
Hi, i use the Template "Ashley" in 2 Installation. In the first installation lookes the Main-Menue very good. See here: http://hokineu.striewski.biz
In the second installation (we have changed the server), the Main-Menue lookes wrong. The title-attribute shall not be seen to every time. But only as a tool-tip (as in the first installation). Here is the second installation with the problem: http://www.hoffnungskirche-herten.de
Can you help correct the error?
Regards, Silvia Striewski
  1. http://www.hoffnungskirche-herten.de
Thank you for your help very much!
LG, Silvia
To disable the subtitle display try adding the following to the Custom CSS field of your templates parameters...
.hornav > ul > li > a::after {
display: none;
.hornav > ul > li > a {
padding-bottom: 0;
Thank you!
It looks better. :D I would prefer it so: http://hokineu.striewski.biz Without title-attributes in the first view. And the title-attribute only s a tool-tip.
If it is not possible, then it can still remain so.
Thank you for your help.
LG, Siliva
We have made some changes to your top menu styling to better accommodate your menu items.
