1. suzannek
  4. Tuesday, 10 December 2019
I have a problem with the layer slideshow/header/mobile menu on the lovely Ariana template.
The mobile menu bars and secondary menu bar are not showing correctly in the 955-1140px viewport size range.
The usual menu disappears as ought at larger sizes but when the viewport is made smaller the menu bars replacing it are not properly located as to be fully visible and the secondary menu bar does not visually fully extend across the viewport.
Would you please take a look and see if you can suggest anything?
The site is on:
http://test-6-co-uk.stackstaging.com/index.php
Thanks for any assistance,
Suzanne
Hi Suzanne
.slideout-toggle-open,
.slideout-toggle-close {
margin-top: 0;
That worked perfectly.
Thanks for a swift reply with the solution.
Suzanne
Hi Suzanne
Admittedly I can not replicate this issue on a device. To resolve the issue presented on responsinator, could you try adding the following to the Custom CSS field of your template settings...
.is-sticky .header_nav {
background-color: #170500;
New Year Greetings to you.
Thank-you very much for looking into this, I tried the CSS amendment, it looks unchanged on the Responsinator.
So it might just be how the Resonsinator is rendering it.I will leave it at that until I learn any differently.
Your assistance is very much appreciated.
Suzanne
I think that this is not quite sorted after all.
The responsinator is still showing the original issue but only on iPad landscape width: 1024px (on scroll).
responsinator all sizes
responsinator ipad landscape 1024px
web site
Any suggestions? I think this device is what my client is using...
Thanks for any advice
Suzanne
