I have a problem with the layer slideshow/header/mobile menu on the lovely Ariana template.
The mobile menu bars and secondary menu bar are not showing correctly in the 955-1140px viewport size range.
The usual menu disappears as ought at larger sizes but when the viewport is made smaller the menu bars replacing it are not properly located as to be fully visible and the secondary menu bar does not visually fully extend across the viewport.
Would you please take a look and see if you can suggest anything?
The site is on:
http://test-6-co-uk.stackstaging.com/index.php
Thanks for any assistance,
Suzanne
- suzannek
- Tuesday, 10 December 2019
