1. Ale
  4. Tuesday, 09 February 2016
I have a problems with Central template:
1.- How changue text color in sub menu? see my web: (section "productos";)
http://www.bercometal.cl/index.php/proyectos
2.- The sub menu is back of slideShow in the home main menu (image attached)
3.- In mobile devices the web is not centered. (image attached)
Regards,
Hi Ciaran thanks a lot!
In mobile devices the web is not centered. The problem is not solved with the updating my slideshow. (image attached) :(
Updating your slideshow module appears to have resolved the issue.
To answer your email question custom CSS can be applied to a single page by creating a template style to which you will add the custom CSS and assign to the menu items of your choice. For details on creating multiple template styles may I suggest the following article... http://www.joomla51.com/tutorials/item/creating-multiple-template-styles
It work... I send you a mail.
Thank´s Ciaran.
Hi Ale
1. To amend try adding the following to the Custom CSS field of your templates parameters...
.hornav ul ul li a {
color: #ffffff;
2. Try also adding the following to the Custom CSS field of your templates parameters...
.hornavmenu-bottom {
z-index: 105;
3. May I suggest sending temporary administration access to your Joomla installation to info@joomla51.com and we will examine this issue further. For our reference please paste a link to this post in your email.
