i have a problem when i want to create or edit an article Joomla on the frontend.
i have tested with severals editors WYSIWYG (TinyMCE and JCE) it is the same. When the page loading i can't modify the fields. The page is frozen. I can't do anything ...
If I test with the minimum number of plugins and I deactivate JCH Optimize, it's the same. Each time I purge the browser cache and tried on several web browsers.
If i test with another template it's ok (a native template of Joomla for example).
I send you access code of my project.
